04-10-2025
11:13
20:10
ManuFitbit
04-10-2025
11:13
20:10
ManuFitbit
My Versa 3 won't turn on after being on charge. I had a situation where the logo was stuck onscreen so disconnected from my phone, then reconnected. The logo is gone but replaced by a blank screen. Tried holding down the side button but no vibration even after 30 to 40 secs. Done this while charging and while it's on my wrist and while it's loose. Any advice please? Thx
Moderator edit: clarified subject.
04-10-2025 14:15
04-10-2025 14:15
Same thing is happening to me. It was glitchy the past few days, tried to reset and now the logo keeps flashing
Best Answer04-10-2025 20:01 - edited 04-10-2025 20:01
Hi @DeanC77 @Amgw. Welcome to the community forums.
Thank you for sharing the details regarding the difficulties that you are experiencing with your Fitbit devices.
Please make sure @DeanC77 to follow the steps listed here: Why isn't my Fitbit device's battery charging?
@Amgw please confirm that you tried the restart as indicated here: How do I restart my Fitbit device?
Best Answer04-11-2025 05:22
04-11-2025 05:22
Thank you for the message. I have done everything as advised but nothing is happening
Best Answer04-13-2025 00:17
04-13-2025 00:17
I have the same problem
Best Answer04-15-2025 14:53
04-15-2025 14:53
I have the same issue. I have a flashing logo and the Fitbit Versa 3 is not working. It also cannot be found in the app.
Best Answer04-20-2025 08:57
04-20-2025 08:57
I stopped using my versa 3 in may 2023 because it blacked out, and wont charge (just get heated but no lighs nor vibration).
I stopped using it.
Last monday I grabbed after almost two years and charged it and worked perfeclty for a week, yesterday died again, tried all the tips ond this thread and nothing happens.
Best Answer04-23-2025 13:03
04-23-2025 13:03
I've just had the same thing happen. It was fine on my wrist recently charged at 80% and it went dead. It is just a black brick. I've done all the things suggested and it is still completely unresponsive. Please advise. Thanks
Best Answer05-16-2025 04:34
05-16-2025 04:34
Did u try connecting it with the laptop and then pressing and holding the button.
