06-06-2023
04:03
05:39
06-06-2023
04:03
05:39
Hello, Fitbit community I am writing this because need some help the issu is when I plug my Fitbit into charger the red box with 0% comes up and then normally goes off when been plug in and then the Fitbit logo will show but this time noting happing so I unplug it and moved it to other side off the room and the same thing is happing.
I am wording do I need a new changing cable.
Thank you.
06-06-2023 05:41
06-06-2023 05:41
Hello there, @SunsetRunner. Thanks for stopping by in the Community Forums and sharing the details about the issue with your Versa 3.
If you haven't done so yet, I'd recommend trying the steps below:
Best Answer06-06-2023 06:15
06-06-2023 06:15
Hello,
I have just tried what you said I cleared it with a bit of water on the teies and dried it straight away on the back off the Fit bit I have also ordered a new cable Because I have had the same one since I got and I did get 2nd hand.
Best Answer06-06-2023 06:31
06-06-2023 06:31
@SunsetRunner Thanks for following the tips and recommendations I've provided above. Is your Versa 3 working now?
Best Answer06-06-2023 07:42
06-06-2023 07:42
I have done all of the above thank you for your thoughs but for some reason nothing is working I am hopping this a cable issue do you think that could be possible because I have brought a new cable is arriving tomorrow if not I do not know what to do is there somewhere I can get my Fitbit repaired.
Thank you.
Best Answer06-06-2023 08:00
06-06-2023 08:00
This is what I get when I plug the cable in and I have left it on carge for about an hour I unplug it put it back on and is giving the same photo as it did when I first plug it in . This is the photo. Is this a cable issue or a battry issue ? pleas let me know .
06-06-2023 10:57
06-06-2023 10:57
@SunsetRunner Thanks for the information provided and the image attached.
If you've bought a charging cable, please test it once it arrives to determine whether the charger is the issue. If you continue having issues, please let me know so I can continue to assist you.
Best Answer06-09-2023 02:29 - edited 06-09-2023 02:34
Hello, Fitbit team i am letting you know the new cable did not work i am still geting the same sreen showing the red battry erre also since geting the cable and a new issu has come up with the fitbit itself i was trying it with new cable i placed it on and after about an hour stil nothing so i decid to take it off the charger so it would not overheat and to my surpris when i was take it off the the carger the sreen fell off just hanging on the with the wire coning them i would normly recomd FitBit i am thing of geting a new one becouse i still pefore them over any other smart wach i know this long shoot but i have been with FitBit since 2016 i was wording if i could get a disscount on a new one if i show the immge of the new falt becouse is now unable to use.
Thank you.
