08-14-2023
08:21
11:29
08-14-2023
08:21
11:29
Hello,
I got a versa 3 as my ionic replacement and have just started having issues. My watch had been working fine up until last week when I put it on to charge and it wouldn't charge. I cleaned the pins on the charger and the ports on the watch and then it started charging. however it instantly charged to 100% and the touchscreen is not responsive. If I take it off of the charger then it instantly dies because it's not truly charged.
Is there a way I can try to hard reset my fitbit? I can't open settings to factory reset it because the touchscreen is unresponsive and I'm a little sad that it died about 2-3 weeks to 1 month after the warranty ended.
Any help would be appreciated.
Thanks,
John
08-15-2023 11:02
08-15-2023 11:02
Hello moderator who changed my subject. The Fitbit does not work on the charger as I am unable to use the touchscreen or wear it for any benefit. If by works you mean powers on and will sync with the app, then that is correct but I can do nothing else with it.
Best Answer08-18-2023 08:33
08-18-2023 08:33
I spoke with the help chat and was unable to get a response, does anyone on the forum here have any help?
Best Answer08-18-2023 08:46
08-18-2023 08:46
the moderator seems to edit but not answer- pfft
