10-17-2020
15:20
20:52
10-17-2020
15:20
20:52
My brand new versa 3 keeps rebooting itself. I am not doing anything or touching it. I will feel a vibration on my wrist while I am sitting, and when I look at my watch it shows the fitbit logo and reboots. It has been doing this since I got it less than a week ago and does it several times a day. It's rather annoying. Anything I can do to fix it?
05-29-2021 06:47
05-29-2021 06:47
Best Answer06-20-2021 17:57
06-20-2021 17:57
My continuesly keeps rebooting. How can this be resolved?
Best Answer06-20-2021 19:24
06-20-2021 19:24
06-21-2021 00:07
06-21-2021 00:07
Best Answer06-23-2021 00:45
06-23-2021 00:45
Mine reboots a lot, but it seems to be when i lean on it. For example I'm a great one for crossing my arms. If my Versa face is pressed on for about 10 secs it restarts.
I have only ever used a fitbit clock face.
Not really causing a problem, but it is annoying
11-07-2021 06:46
11-07-2021 06:46
Mine too. Seems to be when I'm inadvertently touching the screen for am unusually long time, like crossing my arms. I turned off auto screen wake for a few days and it didn't do it. So I'm sure is related to inadvertently touching the screen.
Best Answer12-14-2021 06:24
12-14-2021 06:24
My Fitbit has been rebooting every 25 seconds for the past two hours.. hard reset doesn't work nor does opening the app. It is fully charged, I haven't downloaded a clock face or new music recently. The screen is completely unresponsive. Please help Fitbit!
12-14-2021 06:31
12-14-2021 06:31
Best Answer12-14-2021 10:53
12-14-2021 10:53
Best Answer12-14-2021 11:03
12-14-2021 11:03
Best Answer03-19-2022 13:01
03-19-2022 13:01
There are definitely issues with these Fitbits. My Versa 2 reboots ever few minutes. Fitbit support is useless and don't expect to get better now that Google owns them. I love the product but doubt i'd buy another since they don't seem to last and there are never any solutions to problems that arise. VERY FRUSTRATING!!!
04-01-2022 22:08
04-01-2022 22:08
My watch is also doing this suddenly... it's able to work perfectly fine throughout the entire factory reset and setup process too without turning off. I've tried at least 10 times now. It will update and install new firmware. And then I try to use the newly set up watch and the problem happens again...
Best Answer04-02-2022 10:14
04-02-2022 10:14
08-13-2022 05:33
08-13-2022 05:33
Yes but what when did u do this
Best Answer10-18-2022 05:41
10-18-2022 05:41
This issue was first reported two years ago and it is still happening? I have had my Versa 3 for about a year now and it just started happening several times a day for no reason. Seems to be hurting the battery life as well. Would love a solution!
Best Answer10-18-2022 10:56
10-18-2022 10:56
Like everything Google, Support is non existent!
They want you to just buy a new one.
Best Answer11-01-2022 08:30
11-01-2022 08:30
Any update on this. Mine just started rebooting a day ago and never reboots to clock screen….
BUZZ…. Fitbit logo…. Dark screen
over and over whether on charger or not!
help please
Best Answer11-01-2022 08:46
11-01-2022 08:46
Best Answer01-21-2023 07:42
01-21-2023 07:42
What's the update? Seems people had this problem 2 years and fitbit haven't fixed it. My watch is 3 weeks old and has reset and rebooted(requiring reinstall on app) 6 times!!
Can anyone recommend a step counter/ smart watch that works?
Best Answer01-21-2023 11:47
01-21-2023 11:47
It was a big waste of money and Google has done nothing to make it better. I'll never buy another s*itbit again!
