05-13-2023 21:28
05-13-2023 21:28
The heart rate data appears to be tracking but the resting heart rate hasn't changed for the past 6 days. Does anyone know how to fix this? It was working until 6 days ago.
05-13-2023
21:42
14:54
05-13-2023
21:42
14:54
Hi @Greendale71 - it depends where you are looking.
Check on the watch, swipe the face to the left, tap on the Today app and tap on heart rate.
If you have properly synced recently it should show there, if not try restarting the watch, do a sync with the Fitbit App and see.
Your watch may also have developed a fault which normally coincides with other symptoms, like short battery life or getting hot when charging, and if so stop immediately .
If there are no other symptoms your watch is probably ok.
05-13-2023 22:11
05-13-2023 22:11
All of the hourly heart rate data is showing correctly; however, it's not reflecting in a recalculated summarized resting heart rate. Maybe it will calculate correctly tomorrow.
