03-10-2022
09:36
20:21
03-10-2022
09:36
20:21
There is a long thin white light on the left side of my fitbit. How do I remove this
03-10-2022 11:30 - edited 10-11-2024 05:59
Hi there, @Shiveb1. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Versa 3.
Please restart your Versa 3 as suggested here How do I restart my Fitbit device? If the restart doesn't work try to change your clock face. If this fixes the issue, you can change your clock face back to the original clock face.
Hope that helps.
Hope that helps.
08-22-2022 10:31
08-22-2022 10:31
I’m having the same issue. Long bright white line on left side of the clock face. I restarted, did a reset, changed the clock face and it won’t go away. I haven’t had the watch that long, and love using it, can this be fixed?
