05-25-2022 07:47 - last edited on 12-18-2022 19:55 by
My fitbit versa 3 screen is frozen and I can't get it st sync or even shut down to reboot
05-25-2022 11:38 - edited 11-14-2023 10:59
Hi there, @Babyrubyredgirl. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa 3.
As @Rich_Laue has recommended, please restart your Versa 3 as suggested here How do I restart my Fitbit device? If the restart doesn't work try to change your clock face. If this fixes the issue, you can change your clock face back to the original clock face.
Hope that helps!
Best Answer05-25-2022 09:14
05-25-2022 09:14
Have you tried holding in the side button? This should restart the tracker.
It took about 10 seconds of holding for my Sense to restart.
Best Answer05-25-2022 11:38 - edited 11-14-2023 10:59
Hope that helps!
