02-01-2022 10:42 - last edited on 12-18-2022 20:31 by MatthewFitbit
my versa 3 is stuck in 1 mode
and cannot get it to do anything
02-05-2022 05:03 - edited 07-22-2023 04:02
Hi there, @Cherylmty. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Versa 3.
As a first approach, please restart your Versa 3 as suggested here How do I restart my Fitbit device? If the restart doesn't work try to change your clock face. If this fixes the issue, you can change your clock face back to the original clock face.
If the above doesn't work, check if your Versa 3 is not in sleep mode. When the sleep mode setting is on:
To turn off Sleep Mode, please swipe right from the clock face on your watch to access the quick settings. For more information, see How do I navigate my Fitbit device?
02-01-2022 20:56
02-01-2022 20:56
Hi @Cherylmty - you don't say what mode it's stuck in, but most probably the Always On clock.
Double tap the screen to change to your clock, swipe right to get to Quick Settings and enable the watch icon and disable the others, except brightness.
If you are stuck in swim, double press the button.
