07-22-2025
06:54
08:28
07-22-2025
06:54
08:28
My Versa 3 will not work when worn but seems to do everything normally, including syncing when on charge. Not working when worn makes it rather useless though. It goes entirely blank, or shows a faint square around the outside or the Fitbit logo only. Any help, or is this the end for my little friend?
07-22-2025 08:31
07-22-2025 08:31
Hi there, @TillyShinything. It's nice to see you around the Fitbit Community Forums. Thanks for bringing this to my attention. I'm sorry to hear that your Versa 3 screen is not working properly.
If you haven't done so yet, please try the steps below:
If the above doesn't work, please restart your Fitbit device as suggested here How do I restart my Fitbit device? Note: Restarting the device doesn’t delete any data. If the restart doesn't work try to change your clock face. If this fixes the issue, you can change your clock face back to the original clock face.
Best Answer07-22-2025 08:59
07-22-2025 08:59
Hi Marre, hope you're well. I have tried the above multiple times now. I can confirm the clock face will show the change when it remains on charge. It will not complete the change when it is not on charge and continues to go blank, show a faint outline or the Fitbit logo and disconnects from being paired each time I take it off charge. Many thanks for your message. Is there any hope left for my little friend?
Best Answer07-22-2025 09:58
07-22-2025 09:58
@TillyShinything Since all the steps you tried didn't work, you have a Versa 3 and report that the screen is not working, I suggest reaching out to our Customer Support Team who will be able to take a closer look into this issue and provide further help. Hope to hear some good news soon!
