Versa 3 screen is too dim
ANSWERED
I was wondering is there a way to fix the if I can't see some of the screen i can't see the time
1 BEST ANSWER
Accepted Solutions
Hi there, @Reneetrvls. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Versa 3 and the image attached.
As @Guy_ has mentioned, your Versa 3 seems to be in sleep mode. When the sleep mode setting is on:
  • Notifications, goal celebrations, and reminders to move are muted.
  • The screen's brightness is set to dim.
  • The Always-On Display clock face is turned off.
  • The screen stays dark when you turn your wrist.
  • The sleep mode icon illuminates in the quick settings.
To turn off Sleep Mode, please swipe right from the clock face on your watch to access the quick settings. For more information, see How do I navigate my Fitbit device?
2 REPLIES 2
Hi @Reneetrvls - if brightness is the issue, did you try swiping the watch face to the right to get to Quick Settings and make sure that Sleep mode is off as that dims the screen and in watch Settings check you haven't chosen Dim for brightness.
It may be just the photo, but the watch face needs to be cleaned regularly for it to work right.
If you are in a function pressing the back button will get you out if it, for swim mode press it twice with dry hands and watch.
