02-28-2021
14:51
20:47
02-28-2021
14:51
20:47
My screen is always lite up with time.. drives me mad during night any advice on how to turn it off?
02-28-2021 15:56
02-28-2021 15:56
A couple of choices: Screen Wake or Sleep Mode. You can access both scrolling left (swiping right) from clock face to Quick Settings.
Screen wake is the icon with watch; you can change it from Automatic to Manual so it only lights up with button press; but then you have to remember to switch it back in the morning if you want it to come on with wrist turn.
Sleep Mode - the icon with the moon; you can toggle it on or off similar to Screen Wake, but it also does a few other things to avoid sleep interruptions: turns on 'do not disturb' and sets brightness to Dim. If you have a regular sleep schedule, you can set the hours for when to turn sleep mode on and off so you don't have to remember it. You can set that in Settings > Quiet Modes.
02-28-2021 15:56
02-28-2021 15:56
02-28-2021
23:26
05:35
02-28-2021
23:26
05:35
Sleep mode also sets screen wake to manual, so you don't have to do it as well.
Hence @JohnnyRow good suggestion to setup a sleep schedule in Settings on the watch.
And as a side benefit you get better battery life during a sleep schedule with less screen activity and brightness.
Best Answer07-24-2022 02:16
07-24-2022 02:16
If you switch on the quiet mode toggle on the watch does it have a specific time it goes off at night and come on in the morning?
Best Answer07-24-2022 02:31
07-24-2022 07:24
07-24-2022 07:24
@SBFFC wrote:If you switch on the quiet mode toggle on the watch does it have a specific time it goes off at night and come on in the morning?
If you turn on Sleep Mode in Quick Settings, you have to turn it back off yourself, but in the full Settings App as @Guy_ noted, you can set the on/off schedule yourself.
Best Answer08-03-2022 04:32
08-03-2022 04:32
So I have sleep mode set to start at 11pm and turn off at 7am... But my screen still wakes me up at night by turning on when I roll over. I literally took my watch off and shoved it under a pillow at 3am!
What gives?
04:44
05:35
08-03-2022
04:44
05:35
Hi @BadRabbit - did you check the sleep schedule is working, after 11pm press the button, swipe the watch face to the right to get to Quick Settings and make sure Sleep is turned on, Always On is off and Wrist wake will be off.
If it still wakes you and you are left handed wear it on the other arm at night, you could be getting accidental button presses
Lastly if it is none of those, change the clock face to another one.
Best Answer09-22-2022 01:28
09-22-2022 01:28
Ok, thanks.
I even have it set to wake on button push only. So it's really frustrating.
I love my watch face, but I'll try another one and see if that helps. 👍
01:37
13:00
09-22-2022
01:37
13:00
@BadRabbit- you don't say if you get a vibration as well, but a few things to verify.
If no solution a factory reset may be required, you can chat via the Fitbit App, click profile photo, Help & Support, Contact Customer Support.
