09-17-2021
04:27
20:43
09-17-2021
04:27
20:43
When I scroll up to be able to see daily stats from the clock face it is just a black screen.
I’ve tried restarting my watch and fully charging it, but it keeps happening.
09-17-2021 04:41 - edited 03-15-2024 16:19
Hi there, @Hancockc. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa 3 before reaching out.
Since the restart hasn't worked, please try to change your clock face. If this fixes the issue, you can change your clock face back to the original clock face.
Hope that helps.
Hope that helps.
11-28-2021 13:52
11-28-2021 13:52
This happened to me and the suggsation doesn't work to fix it.
11-28-2021 14:01
11-28-2021 14:01
However...what you should try is to restart. Hold the side button ten seconds until the fitbit logo comes up. That fixed mine
01-17-2022 16:05
01-17-2022 16:05
That worked for me, thanks.
