01-01-2022
05:58
20:40
01-01-2022
05:58
20:40
Hi,
I just received a Versa 3 and started using it to track my runs. When I look at the map, it only shows the route I followed starting from the 1st kilometer. Although the total distance seems correct, I would like to have the detail of the 1st kilometer. Any idea of why it is not showing, and how to enable to show info/map from the start and not only from the 1st kilometer?
Since I also export the activity to Strava, the information of the 1st kilometer is missing there as well.
Thanks!
01-01-2022 06:31
01-01-2022 06:31
Hello @SunsetRunner and welcome to the Community forum. I have two questions. First, are you making sure that the GPS has connected (your Versa 3 will vibrate) before you start your run using the Exercise app? Second, the Versa 3 has a Run Detect feature. If you start running without using the Exercise app, your Versa 3 will vibrate, let you know that it senses a run, then ask if you want to use the GPS and the Exercise app. Are you using this feature? Both of these scenarios will only give you a map from the point where the GPS connects.
It can take several minutes for the GPS to connect.
Laurie | Maryland
01-01-2022 11:10
01-01-2022 11:10
One more thought about the distance. your tracker will use steps times stride to determine distance when a GPS lock has not been made
