11-30-2022
21:24
16:58
11-30-2022
21:24
16:58
My versa3 wouldnt sync with my phone at all so clicked factory reset after trying every thing community's suggested. Now it wont responded when I try to restart. Please help.
12-01-2022
05:25
11:11
12-01-2022
05:25
11:11
Hi @Macca63 - if you factory reset a watch, due to a bug in the process, it is possible to brick it so it doesn't work anymore, especially if you don't give it time to complete the process.
Though charging it may wake it as suggested by @MarkMM .
Generally if you let it run down completely and try and start it, it will show 0%, and if partially charged will show nothing, then you know it's of no use anymore.
12-01-2022 04:38
12-01-2022 04:38
@Macca63 Putting it in the charger should wake it up?
05:25
11:11
12-01-2022
05:25
11:11
12-01-2022 05:25 - edited 12-05-2022 03:50
Hi there, @Macca63. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa 3 before reaching out.
I agree with @MarkMM, as seems that the factory reset drained the battery and also looks like the battery may not be charging properly and therefore, it does not turn on. So, I recommend that you follow these steps:
If you continue having syncing difficulties, please see Why won't my Fitbit device sync?
Hope that helps.
Best Answer12-04-2022 22:37
12-04-2022 22:37
Your absolutely right. Never before have I put any thing " back to factory reset". After speaking to customer services there was only one place for my versa3. Luckily it was still under warranty 😄😁new pebble versa3 in the post no fuss. Thanks for your response.👍
12-05-2022 03:51
12-05-2022 03:51
@Macca63 Anytime! I'm glad to hear our Support Team was able to help.
I would like to invite you to visit our Health & Wellness where you will find great tips and encouragement from other members.
Happy stepping!
12-08-2022 13:43
12-08-2022 13:43
Hello I did the same thing and my versa 3 stopped while it was resetting and it wont work now
Best Answer12-08-2022 19:36
12-08-2022 19:36
Hi @SunsetRunner - there exists a bug in the factory reset process that sometimes kills the watch.
However if it is something else try chat via the Fitbit App, click profile photo, Help & support, Contact Customer support, they might just be able get it working from it's current state.
Best Answer12-08-2022 19:44
12-08-2022 19:44
12-22-2022 01:52
12-22-2022 01:52
Go into your phone's Bluetooth settings and look for all Fitbit devices that show as paired.
Remove all of the Fitbit devices that show up.
Restart your phone.
Run the Set Up process once again as if you were using a brand new Fitbit.
Regards,
Will
Best Answer12-22-2022 06:49
12-22-2022 06:49
Best Answer12-22-2022 06:59
12-22-2022 06:59
@SunsetRunner- did you see this link, just in case it's only because the battery ran down and needs charging - How to check charge cable - Sense/Versa 3 won't charge, won't start or blank screen
Best Answer12-22-2022 07:30
12-22-2022 07:30
Best Answer12-22-2022 07:34
12-22-2022 07:34
Best Answer12-22-2022 07:38
12-22-2022 07:38
@SunsetRunner - how do you know it's fully charged? If you are looking in the Fitbit App, check when it last synced. It could be a while ago.
Best Answer12-22-2022 07:42
12-22-2022 07:42
Best Answer12-22-2022 07:48
12-22-2022 07:48
@SunsetRunner - if your watch is showing 100% when on charge can you do another factory reset with button?
Best Answer12-22-2022 08:17
12-22-2022 08:17
Best Answer12-22-2022 08:33
12-22-2022 08:33
@SunsetRunner - it may not be responding to your touch, to operate the button squeeze the watch between thumb and first finger so that the fleshy part of the thumb covers the button.
Can you try the factory reset that support got you to do when it's on charge or when it's not charging whichever might work.
Best Answer12-22-2022 08:42
12-22-2022 08:42
