03-12-2023
15:04
04:42
03-12-2023
15:04
04:42
Got my Fitbit Sense wet at the beach and it quit working. What do I need to do to get it to turn on?
Best Answer03-14-2023 04:44 - edited 06-07-2023 03:54
Hi there, @JP1000. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Versa 3.
If your device got wet, it’s important to take it off and dry it well before putting it back on. On the other hand, if your device has come into contact with any liquid other than fresh water, you should clean it with fresh water and a soap-free cleanser and dry it with a lint free-cloth. I'd also follow @Heather-S's tips and recommendations.
If you've done the above but to no avail, please try restarting your Versa 3. For instructions, see How do I restart my Fitbit device?
If the restart doesn't work either and your watch hasn't vibrated for the restart process, I'd recommend trying the steps below:
If none of these steps work, please follow @Guy_'s advice as the best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
I've moved your post to the Other Versa Smartwatches board for organization purposes.
Best Answer03-12-2023 15:45
03-12-2023 15:45
@JP1000 You can try putting it in a bag of rice to absorb the water that is in the device. I'd leave it there for 12-24 hours and then put it on the charger to see if it comes to life.
03-12-2023
22:02
11:31
03-12-2023
22:02
11:31
Hi @JP1000 - to add, be careful when charging, if it gets hot stop immediately, as it is dangerous.
If you are still within warranty it should be replaced if it is subsequently not working correctly, for instance much shorter battery life, or functions not working.
