05-31-2022
18:55
18:00
05-31-2022
18:55
18:00
I have a Fitbit Versa 3 that has failed due to water damage. This model is advertised as waterproof up to 50m. I spent an hour in the pool yesterday while wearing my device and it appears to be toast. It is endlessly power cycling on its own. The screen is mostly either blank or displays the fitbit logo. Occasionally the face will appear, but swipes and touches don't work. I contacted fitbit support and their "solutions" were to restart the device (doesn't work since the device is constantly doing this on its own) and to try changing the clock face for some reason (which also didn't work because nothing is syncing due to power cycling.) Their final tip was to do a factory reset, which surprise surprise, doesn't work while the device is continuously power cycling on its own. Has anyone experienced this and had any luck getting fitbit to actually resolve? Been a customer for 6 years and have owned several models and am very disappointed with this device failure and poor attempt at resolving by fitbit support.
05-31-2022 22:10
06-02-2022 06:32 - edited 07-17-2024 07:57
Hi there, @Sam_M1. Welcome to the Community Forums. We‘re taking your comments and sentiments in regards to our products and services into consideration.
Please feel free to reach out to our Support Team once again if you have any further questions or concerns regarding the outcome of your case. Since you have reported this matter to our Support Team, please note there's nothing left we here in the community can suggest other than reaching out to our team again.
Thank you for your understanding.
12-26-2022 18:18
12-26-2022 18:18
I'm having the same issue. What was the resolution for this?
12-26-2022 21:05
12-26-2022 21:05
Hi @Laksfitness - did you check the other posts in this topic?
