08-18-2022
00:02
17:25
08-18-2022
00:02
17:25
I went swimming and before I went I googled if my versa 3 was waterproof and it was. After swimming for about 18 minutes it shows the logo and stops responding, I thought it was dead but it wasn't. I go home and put it on the charger and the buttons and the screen stop responding. It gets better though, it then says the temperature is too low for operation. S.O.S 😭😭
08-18-2022 07:18
08-18-2022 07:18
Hi there, @Duckk. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Versa 3. I understand where your concern is coming from and how you must be feeling.
If your device got wet, it’s important to take it off and dry it well before putting it back on. On the other hand, if your device has come into contact with any liquid other than fresh water, you should clean it with fresh water and a soap-free cleanser and dry it with a lint free-cloth.
If you've done the above but to no avail, please try restarting your Versa 3. For instructions, see How do I restart my Fitbit device?
If the restart doesn't work either and your watch hasn't vibrated for the restart process, I'd recommend trying the steps below:
If the above doesn't work, the best way to get help for this problem is to chat with us online once again or give us a call. Click here to get connected.
We hope your issue is solved soon.
Best Answer08-18-2022 16:18
08-18-2022 16:18
It still isn't working. And now it's dead and won't charge 😞
Best Answer08-18-2022 16:25
08-18-2022 16:25
@Duckk I appreciate you had followed the tips and recommendations provided above. I understand how you must be feeling.
At this moment, I’ve reached the limits of what I can do for you here on the public community forums. The best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
Best Answer08-24-2022 17:53
08-24-2022 17:53
Idk honestly. Screen won't work and the button only works if it is charging? The button factory reset doesn't work either. I've reset it multiple times but it's still the same two problems, screen doesn't work and button doesn't work off charger. Helppp pleaseeee
Best Answer08-24-2022 18:36
08-24-2022 18:36
https://myhelp.fitbit.com/s/support?language=en_US
Best Answer08-24-2022 23:04
08-24-2022 23:04
Tried that lol. I think I have to update it honestly
