07-23-2023
15:36
04:36
07-23-2023
15:36
04:36
Went for a swim and now my versa 3 won’t turn back on? Confused as it’s water resistant and now it’s not working?
07-24-2023 04:38
07-24-2023 04:38
Hi there, @Vkelly95. Welcome to the Fitbit Community Forums. Thanks for the details provided in your post about the issue with your Versa 3.
If your device got wet, it’s important to take it off and dry it well before putting it back on. On the other hand, if your device has come into contact with any liquid other than fresh water, you should clean it with fresh water and a soap-free cleanser and dry it with a lint free-cloth.
If you've done the above but to no avail, I'd recommend trying the steps below:
If the steps don't work, please follow @NellyG's advice and chat with us online or give us a call. Click here to get connected.
07-24-2023 03:34
07-24-2023 03:34
Hi @Vkelly95 Unfortunately it sounds as if your Versa 3 leaked and let so e water in. If it is still under warranty then Fitbit Support will probably replace it. If it is not under warranty then you will need to buy a new one.
Helen | Western Australia
07-24-2023 04:38
07-24-2023 04:38
