10-01-2023
01:58
03:51
10-01-2023
01:58
03:51
I went for a swim and now my Versa 3 won’t turn on! I have tried holding the button for ten seconds and it’s not working! Can you please suggest another solution! Thanks 😊
10-01-2023 03:56
10-01-2023 03:56
Hi there, @Eruve74. Welcome to the Fitbit Community Forums. Thanks for the details provided in your post about the issue with your Versa 3 and your time in trying to troubleshoot it before reaching out.
If your device got wet, it’s important to take it off and dry it well before putting it back on. On the other hand, if your device has come into contact with any liquid other than fresh water, you should clean it with fresh water and a soap-free cleanser and dry it with a lint free-cloth.
If you've done the above but to no avail, I'd recommend trying the steps below:
10-01-2023 03:56
10-01-2023 03:56
