12-22-2023 08:16 - last edited on 12-23-2023 04:03 by MarreFitbit
My Versa 3 will not restart no more and customer support can’t help since I’ve had this watch for few months over a year. Unfortunately, this was the third Versa watch to die on me within four years, all due to internal failures. I take good care of my watches but maybe the product is not meant for a daily usage! Looks like major reliability issues with Fitbit products .
12-30-2023 23:08
12-30-2023 23:08
Hi @MmmmmmTBB - did you read through the responses?
Sometimes the symptoms are similar but the causes are different so it is good to itemise what is going on and what you have tried and you may get a better response. Maybe even start your own topic to get responses specific to your case only.
12-30-2023 23:19
12-30-2023 23:19
Yes of course I did, and another similar thread too (which has some incredibly convoluted button pressing which worked for some people)(but not me). I’ve decided to buy a new one.
12-30-2023 23:22
12-30-2023 23:22
12-30-2023 23:27
12-30-2023 23:27
@MmmmmmTBB - thanks, if you are going to replace your watch be sure to do good research first, especially if not the same model or brand.
12-31-2023 00:11
12-31-2023 00:11
