06-16-2022
13:51
17:58
06-16-2022
13:51
17:58
Please help my versa 3 keeps flashing the logo, I can’t turn
it off or on . Please help
06-16-2022 16:30 - edited 11-16-2023 02:55
Hi there, @Alaoo. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Versa 3.
Please note the issue you're having comes from performing a factory reset without first unpairing your Fitbit device from your Fitbit account and phone's Bluetooth settings. With that being said, I suggest following the steps below in the order listed:
If you can't get started with your Versa 3, usually a missing requirement is the cause. Carefully review the requirements provided in the help article Why can't I set up my Fitbit device?
Hope that helps.
Best Answer06-16-2022 16:30 - edited 11-16-2023 02:55
Hope that helps.
