05-04-2023
00:08
04:19
05-04-2023
00:08
04:19
The screen went of then logo appear och vibrate then off och this cycle continues till battery died. If I charge the fibit versa 3 again and try to open this problem return till battery died.
I used the watch only for sleep to trace my sleep and wake up me using smart function.
What is the problem
05-04-2023 04:21 - edited 05-26-2023 04:39
Hi there, @Munis. Welcome to the Fitbit Community Forums. Thanks for the details provided in your post about the issue with your Versa 3.
Please note this issue comes from performing a factory reset without first unpairing your Fitbit device from your Fitbit account and phone's Bluetooth settings. With that being said, I suggest following the steps below in the order listed (or making sure you've done them as instructed):
If you can't get started with your Versa 3, usually a missing requirement is the cause. Carefully review the requirements provided in the help article Why can't I set up my Fitbit device?
Best Answer05-05-2023 02:11
05-05-2023 02:11
Thanks . I will go through the steps and will give you a feedback.
Best Answer05-05-2023 04:04
05-05-2023 04:04
@Munis Sure thing. I'll be around if you need further help. 😊
Best Answer05-10-2023 03:48 - edited 05-10-2023 14:26
Thanks.. it is working fine now 😀
Best Answer05-12-2023 19:22
05-12-2023 19:22
I tried these steps and still can't get past the logo.
Best Answer05-12-2023 23:58 - edited 05-12-2023 23:59
I understand, it is so frustrating 😫 it happened to me also.
3 days trying but no way. I kept the versa3 away for few days then tried again till I was angry 😠 my teenage son start slapping the watch as he is speaking to versa3: why you made my dad angry, suddenly it started working 😂😂
