07-26-2023
12:08
15:20
07-26-2023
12:08
15:20
My versa 3 is stuck in a restarting loop, it vibrates the fitbit logo shows then a white line flashes across the screen and it turns off then repeats the cycle continously until the battery dies. I've tried restarting it, deleting then reinstalling the app and I've unpaired it turned Bluetooth off & turned my phone off before trying to set the device up again and it's all failed.
07-26-2023 15:22 - edited 07-26-2023 15:23
Hi there, @stephletitia. Welcome to the Fitbit Community Forums. Thanks for trying to troubleshoot the issue with your Versa 3 before reaching out.
Please note the issue you're having comes from performing a factory reset without first unpairing your Fitbit device from your Fitbit account and phone's Bluetooth settings. With that being said, I suggest following the steps below in the order listed:
If you can't get started with your Versa, usually a missing requirement is the cause. Carefully review the requirements provided in the help article Why can't I set up my Fitbit device?
If you continue having difficulties to update your Fitbit device, see Why can't I update my Fitbit device?
Nevertheless, I've seen you contacted our Support Team after posting here and they've already assisted you. If you still need help or have any questions/concerns regarding the outcome of your case, please feel free to contact our team back for further assistance.
Best Answer07-26-2023 23:14
07-26-2023 23:14
I've tried that and it still isn't working. I actually contacted the support team before posting here but accidentally closed the chat when I got a call, and they hadn't managed to help.
Best Answer07-28-2023 02:15
07-28-2023 02:15
All of those have failed, so what do you propose I do now?
