09-19-2023
02:44
03:47
09-19-2023
02:44
03:47
I was trying to log a walk this evening. I clicked on the exercise option but it just went back to the home screen. I tried it many times but had the same result. I then thought i would shut it down and reset it. Now the watch is constantly trying to reboot. I get the fitbit logo and vibration and the screen goes blank. Its doing this over and over again. Would appreciate it if someone could help me.
09-19-2023 03:49
09-19-2023 03:49
Hi there, @Puckyoums. Welcome to the Fitbit Community Forums. Thanks for sharing the details about the issue with your Versa 3 and taking the time to troubleshoot it before reaching out.
In addition to the steps you've done so far, please try the following:
If you can't get started with your Versa 3, usually a missing requirement is the cause. Carefully review the requirements provided in the help article Why can't I set up my Fitbit device?
Best Answer09-19-2023 22:52
09-19-2023 22:52
Thanks. It has now turned off completely and wont turn on dispite being charged. Think its time to return it, only 4 months old which pretty disappointing
Best Answer09-20-2023 00:59
09-20-2023 00:59
This is affecting me as well.
