Versa 3 stuck on Fitbit logo
ANSWERED
Hi. Last night my battery still had 25%, when I hit 10000 steps I felt it vibrate but when I checked it the screen was black and a large battery appeared on the screen with 0%. It’s not charging and all I can see on the screen is the start up logo? I’ve removed the device from my app and tried to reset but keeps saying make sure you are connected? Any other ideas please? It’s only about a year and a half old. Thanks
1 BEST ANSWER
Accepted Solutions
Hi there, @SunsetRunner. Welcome to the Fitbit Community Forums. Thanks for the details provided in your post about the issue with your Versa 3 and your time in trying to troubleshoot the issue before reaching out.
As per the description of your post, it seems like your Versa 3 is having battery issues. If you've tried charging your Versa 3 for more than 2 hours but to no avail, please see Why ins't my FItbit device's battery charging?
If the above doesn't work, connect your Versa 3 to the charger and try the following (while it's connected to the charging cable and even if some of them you've tried already):
  • Unpair your Versa 3 from your phone's Bluetooth and Fitbit app.
  • Unpair other Bluetooth devices that you may also have paired to your phone's Bluetooth settings.
  • Force quit the Fitbit app.
  • Turn off other Bluetooth connections when not in use. This can help to prevent connectivity issues or Bluetooth interference.
  • Turn on the Bluetooth on your phone.
  • Plug it into the charging cable and open the Fitbit app.
  • Set up your Versa 3.
  • If there is no connection, restart your Versa 3.
  • Once your Versa 3 is paired and syncing, please proceed to set up your other Bluetooth devices to your phone again.
With the steps above, what I want you to do is to pair your Versa 3 first to your phone's Bluetooth settings before any other Bluetooth device is connected to your phone.
1 REPLY 1
