10-13-2023
10:59
11:00
10-13-2023
10:59
11:00
12-19-2023 22:55
12-19-2023 22:55
Hi there. Thank you so much for explaining those directions so I can understand them. Lol Unfortunately now my Fitbit is stuck in the data not synced screen with a pink x? I cannot get it to sync or add it to my account on my phone... any suggestions? I've already asked the Fitbit customer service about this but they have not been able to help me so I figured that I would try asking you! Thank you! anything you can suggest to help me with this issue is appreciated!
Abby
12-20-2023 00:29
12-20-2023 00:29
Hey Abby,
I was at the pink X too. You definitely need to remove your Versa 3 from the Fitbit app first and then add a new device and select Versa 3. If it still doesn't find the watch, also try deleting all app data/cache in the phone settings (on Android: Settings > Apps > Manage Apps, search for Fitbit > Clear data), then uninstall the app and reinstall it to make sure there's no old watch data left. You will have to log in again.
But I remember that my Versa 3 was found in a few seconds after I completely removed it from the app and added a new device. So the pink X is actually a good sign. Good luck!
12-20-2023 15:07
12-20-2023 15:07
This is it for me. After trying the instructions 20 times I'm still having no success getting it out of the startup screen. This is the second dead Versa in 3 years, I'm tired of creating so much electronic waste. Garmin has a nice selection that seems to last longer.
12-27-2023 20:05
12-27-2023 20:05
After months of trying to work this out thinking it was a lost cause, I tried MarreFitbit’s instructions and it’s fiiiinally worked! After competing the instructions the Fitbit turns itself off for a while before resetting. Finally!!!!
12-30-2023 00:55
12-30-2023 00:55
Im having the same issue here. Versa 3 stuck on Fitbit logo since 24 hours now. I have tried all instructions for 4 hours now and no pink x or no other messages other than those annoying blue dots.
i hate the side button with all myself now, my finger hurts from pressing that thing so many times.
restarted the phone something like 10 times already, disconnected the device from the app and Bluetooth already, nothing works.
I can’t afford a new one, there must be a way to fix this 😩😩😩😩😩
12-30-2023 02:12
12-30-2023 02:12
That should work.
I only say this because you look hot and you need to stay this way!
12-30-2023 03:29
12-30-2023 03:29
Thanks. But since the Fitbit is stuck with the logo screen I can’t add it to the app.
I tried already a million times and even when trying to factory reset it doesn’t work.
I’ve been trying to contact customer service via webchat but no joy.
So annoying
