02-22-2024
13:09
04:05
02-22-2024
13:09
04:05
Hi,
My versa 3 is stuck on logo and all my data has disappeared 😒
This cost a lot of money , and I've tried all the suggestions I could find and read about however, to no avail .Any other suggestions?TIA
02-23-2024 04:07
02-23-2024 04:07
Welcome to the Fitbit community, @Amanda2110!
Sad to hear that your Versa 3 isn't working as expected. Thanks for having taken your time trying to get things fixed by yourself.
If restarting your device by holding it's button until the Fitbit logo is displayed or changing it's clock face haven't worked either, I'd suggest letting the battery drain until your Versa 3 will shut down. Then give it a full charge and check if it'll be back to working order.
I'll keep my fingers crossed.
02-23-2024 05:01
02-23-2024 05:01
Hi there, @Amanda2110. Welcome to the Fitbit Community Forums. I'm sorry to hear that your Versa 3 is still stuck on the Fitbit logo. I appreciate you taking the time to troubleshoot this issue before posting here. I understand how you must be feeling, I will do my best to help you with this!
It seems like you performed a factory reset while trying to restart your Versa 3, that would explain why it's only flashing the Fitbit logo.
With that being said, please follow the steps below:
If you can't get started with your Versa 3, usually a missing requirement is the cause. Carefully review the requirements provided in the help article Why can't I set up my Fitbit device?
