07-09-2024
11:41
10:05
07-09-2024
11:41
10:05
After a factory reset my watch doesn't start and show up the message "Data not cleared, sync and try again"
Tried to unpair and switch off my telephone, then restarted the watch but always the same... It is blocked on this message
07-10-2024 09:50
07-10-2024 09:50
Hi @stedap. Welcome to the forums.
Thank you for sharing the inquiry regarding the Versa 3.
Please try the following steps in the order listed even if some of them you've done already:
If you can't get started with your Versa 3, usually a missing requirement is the cause. Carefully review the requirements provided in the help article Why can't I set up my Fitbit device?
07-10-2024 11:05
07-10-2024 11:05
Hi,
07-10-2024 11:11
07-10-2024 11:11
