08-26-2021
13:06
20:43
08-26-2021
13:06
20:43
Hi All,
I have reserved the Factory reset by accidentally for Fitbit verse 3 , and the screen come up with Red Cross and the Data not cleared sync and try again. I have no idea what to do. If anyone could suggest me how to fix it please. Thank you very much. Poy
08-26-2021 16:03
08-26-2021 16:03
Hi there, @Ohnupoy. Welcome to the Community Forums.
Please note the message "Data not cleared, Sync & Try again" usually appears when you performed a factory reset without first unpairing your watch from your phone's Bluetooth settings.
With that being said, please try the following steps to solve the issue:
If you can't get started with your Versa 3, usually a missing requirement is the cause. Carefully review the requirements provided in the help article Why can't I set up my Fitbit device?
Hope that helps.
Best Answer08-26-2021 16:03
08-26-2021 16:03
Hope that helps.
Best Answer08-27-2021 12:58
08-27-2021 12:58
Thank you very much. It came back to normal now.
Best Answer08-28-2021 06:07
08-28-2021 06:07
@Ohnupoy Awesome! I'm glad to hear that the steps recommended above did the trick!
I would like to invite you to visit our Health & Wellness where you will find great tips and encouragement from other members.
Happy stepping!
Best Answer05-19-2022 02:57
05-19-2022 02:57
Hi Marre
I was gifted a fitbit and did the factory reset, and now stuck on that red cross and I do not have the phone it was paired to obviously.
what should I do now?
Regards
Anja
05-19-2022 06:46 - edited 05-19-2022 06:46
Hi there, @Duplessis. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Fitbit device.
I'd recommend trying another factory reset. To do so, on your Fitbit device, open the Settings app > About > Factory Reset.
If the above was the method you did for the factory reset, please try this second method:
Now, you can try setting up your Versa 2 by following these directions How do I set up my Fitbit device?
Hope that helps!
Best Answer12-06-2022 07:21
12-06-2022 07:21
These steps are not working for me. I have not been able to sync my fitbit versa 3 and it still has the large red X with Data not Sync'd
Best Answer12-26-2022 20:55
12-26-2022 20:55
Useless instructions. 3 days and can get my Sense responsive. Have followed every instruction multiple times and just stuck at reset failed. Uninstalled app, removed device, restarted phone, Bluetooth on and off. All of these multiple times and just sits with error reset failed. Screen unresponsive so please don't suggest going the device settings. A decent
Best Answer01-07-2023 01:39
01-07-2023 01:39
I used this info and it worked after spending hours trying to resolve.
Best Answer01-07-2023 01:41
01-07-2023 01:49
01-07-2023 01:49
I used these various instructions on my phone.
After hours and resets.
The fitbit was off at the time.
It came on and started syncing!
