12-28-2021
18:34
20:43
12-28-2021
18:34
20:43
My versa 3 won’t open again it keeps showing me a red X and says : data not cleared &try again. I don’t know what I did but I can’t use it anymore because of that.
12-31-2021 05:43 - edited 09-01-2023 07:34
Hi there, @Manap. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Versa 3.
Please note the message "Data not cleared, Sync & Try again" usually appears when you performed a factory reset without first unpairing your watch from your phone's Bluetooth settings.
With that being said, please try the following steps to solve the issue:
If you can't get started with your Versa 3, usually a missing requirement is the cause. Carefully review the requirements provided in the help article Why can't I set up my Fitbit device?
Best Answer12-31-2021 05:43 - edited 09-01-2023 07:34
