Versa 3 stuck on message "Data not cleared, Try & Sync again"
my versa 3 is stuck on the data not cleared sync and try again.
I have followed the other comments on other posts to remove from bluetooth and unsync from the app but this has not corrected it. I have also restarted it and it continues to flash with the cross and to try again.
Help please!!!!!!!🙂
2 REPLIES 2
Hi @amalion  - try removing any entry for the watch from the phone's Bluetooth and restart the phone for good measure
In the phone Fitbit App
Click on profile photo [top left]
Click on  "+ Set up a Device"
If that doesn't work
when you Click on profile photo if the device is still showing remove it
[by dustbin top right]
Then repeat the above process
Follow the installation instructions
Hi there, @amalion. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa 3 before reaching out. @Guy_ Thanks for your help!
I've seen you contacted our Support Team after posting here and they've already assisted you with this matter. If you have any further questions or concerns regarding the outcome of your case, please feel free to contact our team back.
See you around.
