03-25-2021 03:51 - last edited on 12-18-2022 20:47 by MatthewFitbit
My Fitbit Versa 3 constantly defaults to the 'Set up your wallet' screen. I don't want to ever set up a wallet. And I would like to stop seeing this screen whenever I check the Versa 3. Any ideas?
03-26-2021 03:46
03-26-2021 03:46
Hi there, @Brennig. Welcome to the Community Forums. Thanks for sharing the details about the issue with your Versa 3.
Usually that screen will appear when opening the wallet app on your watch by either tapping on it or with left button to access to the shortcuts. While it's not possible to delete the wallet app, please give a try to the following steps to reconnect your watch to your account:
Hope that helps.
03-26-2021 03:46
03-26-2021 03:46
Hope that helps.
03-27-2021 13:30
03-27-2021 13:30
We want/need a way to stop this obnoxious wallet nag.
It pops up waaaay too often, to the point that it feels like the default watch face.
03-30-2021 17:07
03-30-2021 17:07
Hi there, @StopWalletNag. Welcome on board.
If you're getting the same error message as the original poster, please make sure to follow the tips and recommendations I've shared here.
Hope that does the trick for you.
06-15-2021 12:21
06-15-2021 12:21
you said it best....I dont ever want to set up wallet. EVER! Get this D$%M message off my watch!
06-17-2021 03:56 - edited 06-03-2023 11:18
Hi there, @tomster549. Welcome to the Community Forums. I understand how you must be feeling.
If you want to get rid of that message, please make sure to follow the tips and recommendations I've shared here.
06-19-2021 02:55
06-19-2021 02:55
Well I've done this, as you've suggested. I've followed this checklist.
Three times now, I've followed it.
The problem still exists.
In what universe is this an acceptable situation?
06-19-2021 03:06
06-19-2021 03:06
Go to Settings -> Shortcuts on the watch and you can disable the press+hold shortcut - which defaults to wallet.
The problem seems to be long presses somehow getting unintentionally triggered from time to time. Seems that the solution was there all along, just rather harder to find than it should have been.
06-20-2021 14:55
06-20-2021 14:55
I vote for a software fix to make it go away! Like.....now.
08-06-2021 07:08
08-06-2021 07:08
This solution is not reproducible. Like many others it did not work for me.
06-26-2022 07:34
06-26-2022 07:34
I've seen you reply to this question many many times. Your step 3 doesn't even support the original question regarding a Versa 3. I just got one, but I'm wondering if it's outdated already ? The FitBit Pay is useless as you support very few banks, and seemingly only Visa. I wonder if I should have stuck to ApplePay on my AppleWatch ... There is little or no features for Apple and iPhone users. Please prove me wrong 🙂
12-16-2022 16:49
12-16-2022 16:49
That didn’t work for me. I wish we could remove the wallet altogether. It doesn’t work with my bank, so I’ll never be using it.
12-18-2022 22:25
12-18-2022 22:25
Just wondering could removing Device lock, if enabled, help?
12-21-2022 13:06 - edited 12-21-2022 13:10
StopWalletNag's fix worked for me.
"Go to Settings -> Shortcuts on the watch and you can disable the press+hold shortcut - which defaults to wallet."
03-15-2023 17:52
03-15-2023 17:52
hello
I've done 1 and 2 but I can't restart my Versa 3 because it is frozen stuck on Set up Wallet and the button is not responding at all. What do I do now apart from the factory reset? Thanks
