Versa 3 stuck with logo won’t connect to Bluetooth
Hi, my Fitbit verbs 3 is stuck with the Fitbit logo on the screen pressing and holding side button does nothing, it won’t connect with my phone, tapping, swiping screen does nothing??
Moderator edit: clarified subject.
2 REPLIES 2
It's good to see you participating in the community @Sallyb74
Thank you for taking the time to share the details regarding this difficulty experienced. Thank you for trying to fix it on your own.
Please Remove your Versa 3 from your Fitbit account and your phone's Bluetooth settings.
  • Force quit the Fitbit app.
  • Turn off the Bluetooth.
  • Turn on the Bluetooth.
  • Set up your Versa 3 again.
  • If there is no connection, restart your Versa 3.
If you can't get started with your Versa 3, usually a missing requirement is the cause. Carefully review the requirements provided in the help article Why can't I set up my Fitbit device?
Hello.
I have the same issue with my watch, and now that I have disconnected it, the app can’t find it to set it up again.
so far I’ve tried all the steps above without any luck.
