12-30-2024 19:27
12-30-2024 19:27
My device was working this morning then about an hour after I got up, the screen was no longer working but it was still tracking and I could sync with the app and charge the device. After another few hours, it is now not responsive at all and the side button doesn't work. I've tried forcing a restart with the side buttons but this hasn't worked. I'm using the Fitbit app on a Google Pixel 7A
12-31-2024 02:17
12-31-2024 02:17
Mine too. Mine actually stopped synching on Christmas Day. Has anyone got back to you Aoife?
12-31-2024 10:43
12-31-2024 10:43
Haven't gotten a response yet but my mother's Fitbit Charge 5 is also not responding now also and none of the usual fixes have worked on that either
01-02-2025 06:10
01-02-2025 06:10
Hi @Aoife_M and @TheAnniek1 ! Welcome to the Community !
I appreciate your messages, and I'm sorry to hear your devices are unresponsive and aren't syncing. Thank yo for the troubleshooting steps already tried. I'll do my best in order to help you.
Could you please try the following ?
Manually syncing Why won't my Fitbit device sync?
Restart your devices How do I restart my Fitbit device?
Change the clock face How do I change the clock face on my Fitbit device?
Visit our Discussions board where you can share your experiences, meet people and create new topics.Si ma réponse vous a plu, merci de me féliciter. Si votre question a trouvé une réponse, acceptez la solution.If you liked my answer, give me a Kudo. If your question was answered, accept the solution.FR-EN-SPA.
01-02-2025 08:49
01-02-2025 08:49
Hi there my versa three stopped syncing eleven days ago what's going on. I also have a pixel 7a
01-02-2025 11:17
01-02-2025 11:17
I having issues also since start of year - is it an update issue or an issue regarding the take over of fitbit
01-04-2025 14:36
01-04-2025 14:36
Hi @MarioSFitbit, thank you for your message. I've tried the steps you suggested. The screen hasn't worked since I first posted and the side button isn't responsive so I haven't been able to. I uninstalled and reinstalled the app on my phone and used a few different outlets to make sure that this wasn't the reason that the battery wasn't charging. After the screen stopped working, I plugged it and the app showed that it was charging. But this is no longer working now and the app can't find the device. I haven't removed the device from the account as I don't have a way to reconnect them. Any other help you can give would be greatly appreciated.
01-05-2025 05:22
01-05-2025 05:22
Hi @Boyneview and @Tinkerbell46 ! Welcome to the Fitbit Community !
I appreciate your messages, and I'm sorry to hear you are experiencing syncing issues with your watches.
Could you please confirm if you already tried the following steps ?
@Aoife_M Thank you for your message and your troubleshooting efforts. I'm sorry to hear your watch is still unresponsive. In most cases, restarting the device causes sync to be reestablished.
I understand the button of your device is unresponsive. In your particular case, could you please try to remove any dust or dirt by gently using a toothpick or swab around the pimple. If this does not improve the button's operation, you can try cleaning out the debris using compressed air. Hold the watch at arm's length and spray once to loosen any dirt or dust that may have collected around the button.
After that, please try again the restart process : Press and hold the button for 10 seconds until the Fitbit logo appears on the screen, and then release the button.
01-05-2025 06:33
01-05-2025 06:33
@MarioSFitbit, I have tried your above suggestion with no change. The device is still unresponsive. Also, because I reinstalled the app, it is asking me to reconnect the device which I have not been able to do so I can't check the battery status but I have had the device plugged in over night so it should be fully charged. I've only had this device since December 2022 so it's disappointing that is having problems already. I had my Blaze for nearly 6 years before this with very little problems. The battery gave out in the end which I would have expected. Do you have any other suggestions on how to fix the Versa?
01-05-2025 06:39
01-05-2025 06:39
Hi @Aoife_M ! Thank you for your message and for the steps tried.
I'm sorry to hear the situation still persists.
Since the troubleshooting was attempted, I suggest you contact support since they have more tools to find your options. Please follow the link Contact Us.
01-05-2025 06:48
01-05-2025 06:48
01-05-2025 06:58
01-05-2025 06:58
Hi @Tinkerbell46 !
Thanks for your message and for your time.
I'm glad to know your watch is fine now.
I appreciate the steps you shared with us.
My best wishes,
01-06-2025 17:26
01-06-2025 17:26
I did these and my fitbit 3 is still not syncing with my app on my Samsung Galaxy S22 Ultra
01-06-2025 17:28
01-06-2025 17:28
I restarted twice and it didint work
01-07-2025 15:18
01-07-2025 15:18
All sorted - thank you all
