Versa 3 won't change from Celsius to Fahrenheit
I have changed the units several times and synced my watch to the app. My Versa 3 still reads in Celsius not Fahrenheit. Any suggestions? TIA
6 REPLIES 6
Hi, there are 2 temperature settings. One for the Fitbit App and one for the weather.
If the latter is wrong, head to the apps tile in the Fitbit app, select your device tab at the top, select Weather and then Settings, Temperature.
I've done that multiple times and it still gives Celsius.  Help!
Hi @Teacherjeanne - see How to change Temperature - for Weather, Centigrade - Fahrenheit, Versa 3, especially the last line.
The apps tile huh? You have an apps tile? Where would that be exactly? I can't seem to find it
Hi @PDNixon1 - see the post prior to yours. There was an update to the Fitbit App.
Thank you very much!! Why in the heck they would have two separate places to co tell this is beyond me, but thanks for helping me finally figure it out.
