08-14-2022
15:10
17:28
08-14-2022
15:10
17:28
First my versa3 was spazzing out and vibrating and wouldn't let me touch anything on the screen and now it won't charge and keeps saying that it's not at operable temperature and I just took it off my wrist like normal.
08-14-2022 17:01
08-14-2022 17:01
I dont know if it will work but try putting your versa in to the refrigerator for 30 seconds if it dose not work try for 1 minute. Hope I help.
Best Answer08-14-2022 18:24
08-14-2022 18:24
Hello @Turtlgirl
‘I’ve read about this happening with a Versa 3 before. It’s certainly not common. I’d try restarting your Fitbit Versa 3: https://help.fitbit.com/articles/en_US/Help_article/1186.htm.
If restarting doesn’t fix the issue I’d certainly contact Fitbit Customer Service: https://myhelp.fitbit.com/s/support?language=en_US. I find calling them directly or live chat the easiest way to communicate.
😉 Hopefully a restart of your Fitbit will do the trick..if not maybe Fitbit Customer Service can get this sorted out for you.
08-15-2022 16:40
08-15-2022 16:40
I can't restart it because I can't charge it lol. I'll have to try to call them but I don't know what they can help me with if I can't even turn it on.
08-16-2022 04:34
08-16-2022 04:34
Hello again @Turtlgirl
You can restart the Versa 3 without it being in the charger. The reason I suggested contacting Fitbit Customer Service is because you might still be under warranty or they might be able to get it sorted out for you.
Best Answer08-16-2022 05:52
08-16-2022 05:52
It is completely drained so there is absolutely no way for me to turn it on. Prior to it completely dying, I did a factory reset and it's still won't work. I will be calling Fitbit today
