01-31-2022
17:28
20:28
01-31-2022
17:28
20:28
Up to yesterday my Versa 3 was running perfect but I noticed it did not charge over night. I tried 3 different USB sources and now the Versa 3 is completely discharged. I cleaned my contacts on both charger and watch. Did a full factory reset (when it still had power) and measured 4.86 volts across the charging pins but it will not charge. What do I try from here?
02-01-2022 01:12
02-01-2022 01:12
Hi @geneschr - this is quite a common fault with the charge cables and charging. Check the cleaning again and all the points in How to check charge cable - Sense/Versa 3 won't charge, won't start or blank screen
02-01-2022 04:46 - edited 07-20-2024 06:46
Hi there, @geneschr. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa 3 before reaching out.
I've seen you contacted our Support Team after posting here and they're now helping you with this matter. 🙂
We hope your issue is solved soon.
02-06-2022 07:59
02-06-2022 07:59
Yes. It was a defective charging cable. I received a warranty replacement from fitbit today and the watch is charging again.
