07-18-2023
15:03
15:17
AndreaFitbit
07-18-2023
15:03
15:17
AndreaFitbit
Let my wife use my versa 3 & she let it go to 0 charge and now I can't charge the battery.
Moderator edit: format.
07-18-2023 16:03
07-18-2023 16:03
Try cleaning the metal contacts with rubbing alcohol, mine wouldn't charge but a good cleaning fixed it
07-18-2023 21:22
07-18-2023 21:22
Hi @Mrbill216 - as @j_b_141 says, cleaning is important and also follow the instructions in How to check charge cable - Sense/Versa 3 won't charge, won't start or blank screen
