Versa 3 won't connect to my iPhone's Bluetooth
ANSWERED
My Iphone Pro Max (which has been updated to the latest IOS) can't find my Versa 3.  When I first started having problems, I did all the troubleshooting - removed device, reset network, removed app and reinstalled updated version.  Now my iphone's bluetooth can't locate my watch.  When I go to my watch and check the system, it indicates that wifi is off.  Please help, this has been going on for over 2 weeks.  Thank you in advance.
1 BEST ANSWER
Accepted Solutions
Hi there, @KMcCarty63. Thanks for stopping by in the Community Forums. Thanks for trying to troubleshoot the issue with your Versa 3 before reaching out. I understand where your concern is coming from.
In addition to the steps you've done so far, please try the following in the order listed (even if some of them you've tried already):
  • Unpair your Versa 3 from your phone's Bluetooth and also make sure it's no longer connect to your Fitbit app.
  • Force quit the Fitbit app.
  • Turn off the Bluetooth.
  • Turn on the Bluetooth.
  • Set up your Versa 3 again.
  • If there is no connection, restart your Versa 3.
If you can't get started with your Versa 3, usually a missing requirement is the cause. Carefully review the requirements provided in the help article Why can't I set up my Fitbit device?
1 REPLY 1
