05-12-2022 20:05 - last edited on 12-18-2022 19:58 by
Hello everyone! I'm having a major headache with my Vera 3. I bought it last July. It's worked great until a week ago. Now, it won't load past the rebooting screen. I've done everything that it says online and in this community, but nothing has worked. Any help would be greatly appreciated.
05-13-2022 08:50
05-13-2022 08:50
Hi there, @ProudT8. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa 3 before reaching out. I understand where your concern is coming from.
I do not exactly what steps you've done so far, but please try the steps below in the order listed:
If you can't get started with your Versa 3, usually a missing requirement is the cause. Carefully review the requirements provided in the help article Why can't I set up my Fitbit device?
If you manage to pair and sync your Versa 3, please make sure your Fitbit device is running the latest firmware version. For more information, see How do I update my Fitbit device?
Hope that helps.
Best Answer05-13-2022 20:29
05-13-2022 20:29
I tried all those things. Now, my Versa 3 won't turn on, won't charge. It's just dead.
Best Answer05-17-2022 06:34 - edited 11-10-2023 04:49
@ProudT8 I appreciate you had followed the tips and recommendations provided above.
At this moment, I’ve reached the limits of what I can do for you here on the public community forums. The best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
We hope your issue is solved soon.
