10-22-2023
11:24
07:52
10-22-2023
11:24
07:52
Hi
I've recently bought a Versa 3 and I'm unable to connect it to my phone. It finds the Versa 3 and goes to the numbers but when I put the numbers in it doesn't connect. Does anyone know what I can do to make this work?
Thanks
10-23-2023 07:56
10-23-2023 07:56
Hello there, @LJBateman92. Thanks for stopping by in the Fitbit Community Forums. I'm sorry to hear about the connectivity issues you're running with your Versa 3.
To better assist you, may I know if you had in the past another Fitbit device? If so, do you still use it? If that is not the case, I suggest trying the following steps in the order listed:
With the steps above, what I want you to do is to pair your Versa 3 first to your phone's Bluetooth settings before any other Bluetooth device is connected to your phone.
Best Answer10-23-2023 11:36
10-23-2023 11:36
Yes, I've got a blaze which I'm still using as the Versa 3 won't connect
Best Answer10-24-2023 11:37
10-24-2023 11:37
@LJBateman92 Thanks for those details.
I've seen you contacted our Support Team before posting here. Since the steps I've recommended did not work, please feel free to contact our team back so they can continue assisting you. You already have a ticket open with them so it will be easier to follow up.
We hope your issue is solved soon.
Best Answer10-24-2023 11:42
10-24-2023 11:42
The problem is there seems a fault with the versa watches. Very often the logo is just displayed on the screen and won't disappear. I tried logging out of the app and removing the blaze and restarting my phone still it doesn't work. It's not right, people won't be buying Fitbit anymore with all these system problems. I can't even use it, it's useless
