01-27-2022
03:57
20:34
01-27-2022
03:57
20:34
Hi,
My fitbit doesnt work anymore. I can only see the first screen (what time it is). If I want to see more I have to fill in my passcode. I can see it picks the 4 Numbers but then it doesnt do anything. If I want to reset the fitbit it also does nothing.
Can you help me please?
regards,
Lotte
01-27-2022 04:06 - edited 01-08-2024 06:54
Hi there, @lotteloo. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa 3 before reaching out.
Before considering other options, please confirm that you've restarted your Versa 3 as suggested here How do I restart my Fitbit device? If the restart doesn't work try to change your clock face (this process can be done through the Fitbit app). If this fixes the issue, you can change your clock face back to the original clock face.
Hope that helps.
Hope that helps.
01-31-2022 01:22
01-31-2022 01:22
Thnx! Restart wasn’t possible but the change of clock face workt!
01-31-2022 04:44 - edited 08-08-2023 12:00
@lotteloo Awesome! I'm glad to hear that your issue is solved now.
I would like to invite you to visit our Health & Wellness where you will find great tips and encouragement from other members.
