02-12-2022
09:34
20:28
02-12-2022
09:34
20:28
Versa 3 won’t hold a charge for more than two days
02-12-2022 13:46
02-12-2022 13:46
Hi there, @SunsetRunner. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Versa 3.
As with other electronic devices, the battery will depend on the features and how often they're used, such as the GPS, Spotify app or the Always-On display. While this doesn't mean that you shouldn't use them, please take into into consideration the conditions that impact your watch's battery.
That being said, I'd recommend to change the clock face to one designed by Fitbit and please confirm if you've followed the tips and recommendations to maximize your watch's battery life as @Odyssey13 has recommended.
Hope that helps.
02-12-2022 09:37
02-12-2022 09:37
Hi @SunsetRunner see if this article helps you and let us know.
02-12-2022 13:46
02-12-2022 13:46
Hope that helps.
02-12-2022 17:26
02-12-2022 17:26
What not more 2 it’s supposed to last a week. The first month I had it it was fine now 3 days. I have no music or GPS it’s bare minimum and a Fitbit clock face.
02-12-2022 17:28
02-12-2022 17:28
I have a Fitbit clock face. I don’t have GPS turned on. I have turned everything I can off I would like to turn exercise tracking off. It’s supposed to last a week.
02-12-2022 17:29
02-12-2022 17:29
You have the best answer.
02-12-2022 20:26
02-12-2022 20:26
HI @SunsetRunner - here is the complete list of battery drainers check each carefully you should be able to get 6 days - How to resolve the Major issues causing short battery life.
