01-16-2022 10:50 - last edited on 12-18-2022 20:37 by MatthewFitbit
Hello all,
we have purchased a fit bit versa 3 for my mother in law.
she has a Samsung A6 and the watch doesn’t receive any notifications.
is this phone supported for this watch or not?
Update:
The watch has notifications set to on as soon any options within the fit bit app.
Being used to Apple products the watch is very clunky to operate
01-17-2022 07:11 - edited 11-02-2023 03:36
Hi there, @Pip008. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with the Versa 3.
Please note that you can choose 1 app per category. The most common apps for these features are:
However, for "Text Messages" section you can only select your primary text messaging app (that can be WhatsApp, your phone's default Message app or any other). Nevertheless, in "App Notifications" section you can select more apps, for example if you decided that for your primary text messaging app you want it to be WhatsApp, in App Notifications you can enable Messages app.
For more information, as @Guy_ has suggested, please see How do I get notifications from my phone on my Fitbit device?
Hope this helps.
01-16-2022 23:05
01-16-2022 23:05
HI @Pip008 - in principle the phone has Android 10 which is compatible.
Also if you loaded the Fitbit App and have the latest it almost certainly is.
To be sure check the Fitbit App version against What's changed in the latest release of the Fitbit app? and Fitbit-compatible devices
Also check for the notifications How do I get notifications from my phone on my Fitbit device?
Hope this helps.
