08-10-2022
18:00
17:34
08-10-2022
18:00
17:34
My Versa 3 is 100% unresponsive. It won't charge, it won't turn on, it won't reset. It will do nothing. I only got it in April and am upset that it isn't working now.
08-11-2022 05:20 - edited 08-14-2023 10:43
Hi there, @Keepernjd. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa 3 before reaching out.
If you haven't done so yet, I'd suggest trying the following steps:
If the above doesn't work, I recommend performing a factory reset on your Versa 3:
Take into consideration that a factory reset deletes any stored data, which includes all data that hasn't synced to your Fitbit account, your applications, alarms, etc.
If none of the above works, as @SunsetRunner has advised, please feel free to contact our Support Team for further assistance. I've seen you tried chatting with us before, but your chats are getting disconnected. If you have connectivity issues, please try giving us a call instead. Click here to get connected.
08-10-2022 18:23
08-10-2022 18:23
Hello @Keepernjd
I see you have tried multiple troubleshooting steps to fix the issue. Because your Versa 3 is completely unresponsive I’d suggest calling Fitbit Customer Service: https://myhelp.fitbit.com/s/support?language=en_US. I’m sure (based on it being only 4 months) that it’s most likely covered under warranty.
😉 I hope this gets sorted out quickly
08-11-2022 05:30
08-11-2022 05:30
08-11-2022 10:34 - edited 07-16-2023 04:00
@Keepernjd I appreciate you had followed the tips and recommendations provided above.
Since none of the suggestions worked, please feel free to contact our Support Team for further assistance. Click here to get connected.
