08-14-2022
11:13
17:28
08-14-2022
11:13
17:28
Earlier today my watch was at 69% charge and perfectly normal. Then an hour or so later I lifted my wrist to check the time and it was completely dead. The screen is black. The button does not respond to anything. There is no vibration. It won’t charge. It’s just completely unresponsive. This watch is less than 6 months old! What is going on?
08-14-2022 17:05
08-14-2022 17:05
Hello! Try taking the band off and charging it. And if it dose not work then try to buy a diffrent charger and use that! Hope this helps!
08-15-2022 08:54 - edited 07-16-2023 03:42
Hi there, @User666. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Versa 3. I understand where your concern is coming from. @JAYTHEMANDUDE Thanks for your input!
I've seen you contacted our Support Team after posting here and they've already assisted you. If you still need help or have any questions/concerns regarding the outcome of your case, please feel free to contact our team back for further assistance.
