03-19-2023
09:41
10:15
03-19-2023
09:41
10:15
Versa 3 will not reset screen will flash intermittently and the go black I have tried resetting using instructions also tried connected to power supply and it does not reset
Update: Screen stays black
03-19-2023 11:27 - edited 03-24-2023 10:12
Hi there, @gadavis. Thanks for stopping by in the forums and trying to troubleshoot the issue with your Versa 3.
If you haven't done so yet, I'd suggest trying the following steps:
If the above doesn't work, I recommend performing a factory reset on your Versa 3:
Take into consideration that a factory reset deletes any stored data, which includes all data that hasn't synced to your Fitbit account, your applications, alarms, etc.
03-20-2023 11:45
03-20-2023 11:45
I have tried all the resets - the fitbit is still tracing my activities and sends the info to my fitbit account. The screen will just not stay on. It is black, once in a whilte it will show the clock and then go black again. I have tried all the reset holding the button plugging in - I let the device connected to power supply and tried that reset also. I can feel the vibrations when I hold the button. the lights flash on the back of the of the fitbit. and it charges and tracks activities.
03-20-2023 17:55
03-20-2023 17:55
I have cleaned the connections, and tried.the.factory reset several.times. the watch shows a black screen or the logo (and it vibrates) on and off constantly. Both when charging or not. The last update was saturday 03182023. Since then, it has been in this condition. It will not sync either.
