Versa 3 won't respond to anything
ANSWERED
My Versa 3 is unresponsive
no logo
wont turn on
no vibration
won’t charge
1 BEST ANSWER
Accepted Solutions
Hi there, @DebW54. Welcome to the Fitbit Community Forums. Thanks for trying to troubleshoot the issue with your Versa 3 before reaching out.
I agree with @Guy_, so I'd also recommend trying the steps below:
  • Clean the charging contacts on the back of your Versa 3 using the instructions in How do I clean my Fitbit device?
  • If the error "insufficient power source" appears on your device's screen, remove other devices plugged in to your power source, or plug your device in to another source.
  • Try a different USB port or a UL-certified wall charger.
  • Check the alignment and try reconnecting your device to the charging cable. For more information, see How do I charge my Fitbit device?
  • Restart your Fitbit once again. For more information, see How do I restart my Fitbit device?
2 REPLIES 2
Hi @DebW54 - you may have a charging issue, see How to check charge cable - Sense/Versa 3 won't charge, won't start or blank screen
