12-28-2021
		08:35
		20:40
		12-28-2021
		08:35
		20:40
Hello,
My versa 3 will not stay connected to my S9+. Always shows phone is disconnected. When I go into my Fitbit App however, it will sync up. It just won't keep the connection. I checked my App battery setting and it is not set to optimized. Any suggestions for other settings I can check?
Thanks
12-28-2021 15:27 - edited 03-15-2024 16:06
                                          Community Moderators ensure that conversations are friendly, factual, and on-topic. We're here to answer questions, escalate bugs, and make sure your voice is heard by the larger Fitbit team.  Learn more
Hi there, @dodgingwrenches. Thanks for stopping by in the Community Forums and sharing the details about the issue with your Versa 3.
If you haven't done so yet, I'd recommend trying the troubleshooting steps provided in this help article Why won't my Fitbit device sync?
Was my post helpful? Give it a thumbs up to show your appreciation!  Of course, if this was the answer you were looking for, don't forget to make it the Best Answer! Als...
 Best Answer12-28-2021 15:27 - edited 03-15-2024 16:06
 Best Answer01-19-2022 07:26
01-19-2022 07:26
Hello I have the exact same problem. My versa 3 will NOT stay continuously synced. And yes as soon as I go into the fit bit app it will sync. My samsung galaxy S9 phone and my fit bit will be on my person and still have sync issues. I have tried all the trouble shooting suggestions and no luck.
01-20-2022 05:35 - edited 11-13-2023 11:16
@LowL Thanks for stopping by in the Community Forums. I appreciate you had followed the tips and recommendations provided above.
The best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
We hope your issue is solved soon.
 Best Answer01-20-2022 10:03
01-20-2022 10:03
