11-06-2023
04:07
03:23
11-06-2023
04:07
03:23
My Versa worked as a charm with Android 13, but after last upgrade (android 14 on samsung s23) it does not work fine any more!
Versa periodically loses connection with my smartphone and the only way to restore it is to restart the smartwatch.
please fix because it's really boring
11-06-2023 23:06
11-06-2023 23:06
Hi @Daffyno - the issue is one of the problems with the new Fitbit App, see more in "The redesigned Fitbit app is rolling out!" topic in the appropriate iOS or Android app forums.
Unfortunately it would seem likely you are stuck with this version officially. Though there may be some tweaks over time already mentioned there. This could take months to get this test version (requiring considerable reworking) to anywhere near how the previous version was.
